I'm re-habbing and blackfacing a 74 Pro Reverb. I get all the intended work done and fire it up. Works well, looks good, except for this scritchy come and go noise, sounds like a cross between a condor and ripping a window screen, just harsh. While trying to locate the problem, which I admit is giving me fits, I notice the trem is not working, so I decide to get that out of the way first. Turns out the LDR is bad, the LED is flashing, but nothing happening on the resistor side, so I change it, and voila, the trem now works, but the awful noise is now gone as well.
I fail to see how the LDR can inject such a noise into the audio path, even with the resistive side lifted and the intensity turned full off. So I tack in the old LED side again, and the noise returns. I notice at this time that the noise is present with the old LED tacked in, but stops if I ground the trem pedal jack to turn on the trem. Noise returns every time I unground the jack. I installed the new roach and the noise is gone, whether the jack is grounded or not.
If it were causing havoc with the B node I would expect to scope it there and see it, but I do not. I saw it on pin 6 of the Vib channel tube, but not pin 1, nor anywhere on the Norm channel tube. Strange, I am at a loss. The amp is working well now and ready for pick up, but I just don't get what is going on.
pro_reverb_aa165.pdf
