Anyone point me towards the possible culprit? Had a Valvestate 8040 which worked but hissed so loud it sounded like a tsunami. Plugging direct into the fx return it was perfect. As it was doing it on th eclean channel as well I figured that either IC3 or IC4 had gone noisy so I replaced IC3. Success, or so I thought until I put it back together and reconnected its proper speaker. Because I was using teh shop speaker which is 8 ohm instead of the amps 4 ohm and was a distance away I didnt hear what I heard after i put it together. It was like a motorboat but not varying in frequency with anything, probably running about 1500rpm! Only thing I found which altered it was if I turned ch1 treble all the way down it got louder. mid range I could hardly hear it and full up I coudl hear it but not as loud as with it right down. As I pulled and pushed on the pot shaft I got a few dodgy noises so to be sure replaced the pot (VR4). With the brand new pot in I got crackling as I turned it like DC on it? I did try to measure it and metered between the wiper and chassis but that overheated R66 in the speaker. Only briefly, no harm done.
I know Im being lazy here but Ive had a really crap day and am hoping someone takes pity on me! Anyone suggest a solution? Ill try post the schematic. Thanks.
