I have a customer who is running a Voodoo Labs GCX audio switching system to patch his effects through the input and effects send/return of stereo Randall RH50T heads. He is getting excessive hum when going through his effects loop. We've eliminated power supply noise in his effects as the cause. The noise sounds to be in the range of 120Hz, but when plugging straight into his Randalls, the HV supply is quiet and does not seem to indicate bad filtering. The same setup when substituting a Fender Super instead of the Randall head seems to work fine (Although, the Randall is a much higher gain amplifier). At this point I'm thinking there is grounding noise and/or a potential problem in the solid state amplifier driving the loop.
I'd appreciate any thoughts on something I'm missing, or if anyone has any experience with this head or switching system. I've attached some clips, and schematics:
Randall RH50T • RG50TC.pdf
![Click image for larger version
Name: Randall RH50T • RG50TC.jpg
gcx_switcher_manual.pdf
Hum Example w-Randall.mp4.zip
