I have a '96 silver faced Egnater ie4. It has served me well in my band for several thousand gigs. Over the last year or so I occasionally get a "blatty" gated sound on Ch3. I would often open it and poke around a bit but have never been able to touch anywhere that was evidence of a bad joint or anything. Can someone steer me where toward check voltages or something else to help diagnose this problem? Also if anyone has a schematic I would appreciate it.
For the record. I have read and understand all the safety procedures and have been dabbling with pedal builds and some minor mods in my older Fender amp on and off for many years, but I am by no means a tech or truly understand amplifier circuitry. My knowledge is limited to small paint by numbers kind of fixes and mods.
I have checked /swapped known good tubes and it does not remedy the situation. No caps appear to blistered or leaking. I do not see any obviously bad joints anywhere.
Of note: I did have Jeff Bober add (from Budda at the time) a 3 position toggle to ch1 to make the bass switchable so when I switch between my strat and Les Paul I can attenuate or boost the bass as needed. That as well as the other two channels function fine. The issue is only intermittent on the 3rd channel.
Thank you in advance.
Ross T
Towson, Md
Ross T
Towson, Md
