Getting a high frequency oscillation/distortion on the bottom half of the some wave when you start driving the amp.
Probing the 12AU7's causes some nasty oscillations, but it present on them and the 12AX7 driving them.
Preamp is fine and power supplies are good with little ripple.
Swapped out the tubes, they are fine.
Think a coupling cap is flaky?
With output tubes removed signal on grids is perfectly clean and I can probe the 12AU7's and it doesn't go nuts oscillating.
