Marshall JCM SL-X 2100 schematic version
  • Marshall JCM SL-X 2100 schematic version
    I have a JCM SL-X 2100, one of the earliest ones I think. The power board is SLXa -60-00, and nowhere can I find a print of it. The closest version is 2100-60-02, but it is part of the power supply, even though the print says it is the Power Amp CCT. It is in to check out the Hi/Lo power switch, which has holes drilled in the pcb directly behind the switch. Before I lift the board to investigate, I notice the four 5w screen resistors are 470 ohm, not the 1K I see in other later versions. Should I be concerned with this, as there is evidence of some not to savory work having been done in it in the past.
    Nevermind, I was looking at the EL34 version. Scrolled farther down to find the 5881 version, and the values match. This amp has 6L6s in it.
    http://www.thetubestore.com/lib/thet...-Schematic.pdf
      Be aware that there are two versions of this amp (other than 50/ 100W).
      Output tubes may be 5881 or EL34.
      JCM 900 SL X.zip
