Would appreciate any info on this. Strange animal, 2-6l6'ss, 2-12au7's, 1-12ax7, Ink stamp says 100 watts, 650 volts on the pwr tube plates. Is this plate voltage normal for this amp? Thanks in advance.
Univox 1236 Bass Amp, any information
Yes, Univox used a B+ that high.
With todays mains voltages being higher than when the amp was manufactured, you will see the B+ higher still (approaching 700Vdc)
The trick is that the screen voltage is set much lower (330Vdc by the schematic).
Here is the schematic: Univox U-1236 Schematic.zip
Here is the schematic: [ATTACH]45360[/ATTACH]
Originally posted by JMMP View Postsounds more like 20-25 watts. Not done the calculation yet, all voltages are what the schematic specifies, sounds nice just not a whole lot of output.
Justin"Wow it's red! That doesn't look like the standard Marshall red. It's more like hooker lipstick/clown nose/poodle pecker red." - Chuck H. -
Originally posted by Justin Thomas View PostWhat are you using for speakers? A less-efficient-by-3dB speaker can make a 100W amp sound like 50, and there's no reason a speaker can't be broken or inefficient and still sound good...
Justin
Load it with the proper load, 8 ohms or whatever it requires, feed it 100mV 1kHz , set all tone controls to 5, slowly rise volume until it clips and measure output voltage, then do the Math.
100W is optimistic, even with such high voltage, but I wouldnīt be surprised at 70W or even slightly more ... which is LOUD through a competent speaker.
EDIT: If working properly, you have enough power under the hood to kill that Veteran if overdriven with a guitar.
Of course, itīs not a high gain amp at all, think the clean channel on any Blackface Fender.Juan Manuel Fahey
Hi. Don-t think can get 100w from 6l6 pair with such 10k impedance which place more in AB class,think more 60-maybe 70w arround as JMF said. If you want to get 100W from a pair with those voltages change to kt88 5-6K instead. Check also the balance in output stage.
edit: put some resistors into screen grids for stability reasonLast edited by catalin gramada; 10-22-2017, 08:32 AM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
