Hello everybody...Hope you are having a wonderful time......I was given to sets of EL34's...same brand...GT's....two tubes in a set....I am supposed to install the four of them as a matched quad.....anyway, I installed them and the amp has a triode/pentode mode switch....the amp is a Marshall DSL100H......one set is rated as a 5 and the other set is rated as a 6 on the box.......and both are also labeled medium......I installed the set of 5"s in the two center tube sockets and the tubes rated as a 6 are installed in the two outer sockets.....I set up the bias so that when in Pentode mode, the bias is 60 mV on each side...which works out to about 30mV per each tube.......when I switch to the triode mode the bias changes to around 65mV per side...isn't this the mode that only uses the two center tubes?? If so, isn't that reading too high?? I just wanted to clarify this here first before I proceed......any thoughts and suggestions always welcome......
Cheers
Cheers
