Keeps red plating one tube, does not follow same tube but if i switch out different tubes it may change location..I just have some mix matched tubes in it so they are not matched by any means. 470 ohm resistors are good, it’s a different bias section than I’m used to, it has the hum balance and match pot. The (2) 220 bias resistors are good other than one read higher than the other (250)...
1977 Fender Twin
It seems to me like you have multiple problems. Try this.
1) Remove tubes.
2) Clean and re-tension the sockets.
3) Measure bias at the sockets and make sure voltage is good and stays after warm up.
4) Insert known good tubes or try each tube until you get no red plating on any.
5) readjust hum balance and tubes matching.
I don't think it is your problem, but I would change that resistor that has drifted."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
I have already retensioned tube sockets and actually replaced 2 of them. I will swap in some more tubes as well. I found a schematic online but couldn’t make a lot of it, I’m used to the bias circuit up by pilot light..this one has me scratching my head
Don't think of it as adjustable bias. It's just a little tweak to balance between the push and pull sides.
The actual bias is set by a resistor. There may be a fault (like bad bias filter cap) or someone may have changed the bias resistor to a setting that is too hot. Normally they would be biased quite cold from the factory and you would not be able to get any red-plating from tweaking the "matching" pot.
Can you post the correct schematic?Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
So this is the 135W TR? If so the power tube grid leaks should be 47k, the high HT puts more stress on everything. 47k is the limit for 2 x 6L6 sharing.
If the 33k to 0V off the matching pot has been changed to 18k then the bias voltage to the power tubes will be reduced and tubes run hotter.
Originally posted by g1 View Post...Normally they would be biased quite cold from the factory...Last edited by pdf64; 10-28-2017, 09:31 AM.My band:- http://www.youtube.com/user/RedwingBand
After I looked over the schematic a little while last night and everything looked good and then noticed the 33k had been changed out I figured that must be why they are running hot. Somebody has installed new filter caps (F&T and Ruby) and changed that one resistor. Had original Fender tubes in it, one or more were bad it was blowing mains fuse with them in it.
Red plating may not be noticeable until maybe twice the plate limit.
The absence of (obvious) red plating doesn't mean that the tubes aren't idling too hot.
To be sure, there's no substitute for checking the plate / cathode current of each tube.
Fitting 1 ohm cathode resistors are very helpful with this.
