Got a Gallien Krueger 800RB amp in with the complaint that it just stopped working… how very descriptive!
I opened it up and after checking the fuse I checked over the power amplifier section and everything looked fine statically. I turned my attention towards the power supply board and the +-15 volt regulator was in shambles. R3 and R4 were crispy critters, Q3 was blown open revealing it’s die. I didn’t check any further with this regulator, I just replaced all the regulator silicon plus those resistors which fixed things right up for the power supply. I used TIP41C’s for U1 and U4… basically the same thing as TIP31B, just handles more power and most importantly, I had some laying around in the shop.
The power amplifier board has an op amp on it requiring +-15 volts so I disconnected the preamp and checked the +-15 volt rails… they were just fine and the power amplifier seems to check out good so far, but as for the preamp, that’s another situation all together. I’t rails are a dead short so… we got’s to go on a short hunt in the preamp. The first thing I notice on the preamp is that the two 220uf 25v filter caps were bulged and leaking dialectric so, these came right out. I just removed all 6 of the op amps and inspected them individually… oh yeah, once the op amps and those caps were no longer in the circuit the shorted rails disappeared. I guess theres some parts to be replace here but my findings on the op amps just makes me scratch my head… what could have caused this failure?
I checked the power pins on the op amps and this is what I found.
U1 open
U2 good (about a megohm)
U3 short
U4 open
U6 short
U7 short
U5 is a SS Switch and looks to be OK.
Almost every op amp in the entire preamp was either shorted or open, I have never seen this before, what do you think could have caused this?
![Click image for larger version
Name: Screen Shot 2017-10-27 at 1.22.52 PM.png
U1 open
U3 short
U4 open
U6 short
U7 short
