This sad little amp followed me home.
It's beautiful!
Justin"Wow it's red! That doesn't look like the standard Marshall red. It's more like hooker lipstick/clown nose/poodle pecker red." - Chuck H. -
I'm not sure where you read that, but it's actually a 150W continuous sine wave and 300W continuous program according to specs. It's basically the same as the JBL E130 only built by JBL for Fender. Both D&E speakers use the same recone kit. Here's the spec sheet for the E series, which would be nearly identical to the D.
http://www.jblpro.com/pub/components/eseries.pdf
Edit (for clarity): I do not mean to say that the two speakers are exactly identical, but certainly close enough for comparison.Last edited by The Dude; 11-07-2017, 12:58 AM."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
These are the articles that I read. I understand that the "F" at the end of the model means "Fender".
http://www.lansingheritage.org/image...964/page42.jpg
http://www.lansingheritage.org/image...30-2/page1.jpg
I suggest it's a difference in how the power rating was determined at that time. The old rating might be something like "full bandwidth pink noise" or something of the sort. All I can tell you is that I've been reconing these things for 30 years and they will take substantially more than 25W typical music program.
Edit: I'll add- Even if you only put 25W to one of these, it will tear your head off."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
I think this amp will make a great pedal steel guitar amp. It's 135 watts ultra linear transformer clean. I cleaned up all the filth and installed a few capacitors, cleaning the jacks and controls. I will be sure to post pictures of the "After".Last edited by Axtman; 11-07-2017, 03:57 AM.
The D130F was one of the most efficient speakers of its day. If yours has the original cone and the edge wound voice coil then it will produce much more sound pressure level per drive Watt than other speakers of its day. In addition, the weight is relatively low because the magnet material is Alnico V. The magnet structure does a great job of focusing the magnetic force into the voice coil gap. So much so that a metal object, such as a screwdriver shaft are not even attracted to the back of the speaker.
Very nice find!! That amp's definitely worthy of restoration as time & funds permit. In going thru it, I'd recommend pulling the speaker off the baffle board, and inspecting the cone & surround suspension for any cracks. Not that uncommon due to it's age, if you find any. My first JBL speaker was an Original James B Lansing D130, having cork surround and the squared corner round magnet pot. I eventually had to take it to JBL to be reconed, and they talked me out of that 'museum piece' for a different D13F. Back in the days when JBL was on Casitas Ave in Glendale, CA
What model amp is that? I couldn't make that out on the faceplate.
Fender also had Orange frame Gauss speakers back in those days. I still have one of those 15" Orange-frame woofersLogic is an organized way of going wrong with confidence
