Hey guys,
I just picked up ANOTHER Bv120H for 50 bucks. (The second model, still blue tolex'd but the black faceplate and non-script lettering)
This one's got it's own issue.
Guy said he brought it to a tech who said it was the tubes. (Which kinda made sense)
The volume will just... disappear completely. It will come back after a while of waiting, or if you switch the channel sometimes. It seems to happen less frequently the longer the head is on.
First thought, power tubes (I still don't really know the symptoms of when they go bad since I've never really had them fail on me before) - so i ran 2 from the quad in v2 and v3, problem persists. Tried the other two, same. Tried another pair of known working tubes, same.
Inb4 I haven't opened it up yet to take any readings, what is a likely or common cause of volume jutting out and returning?
Volume does not make a difference, so it's not vibration based as far as I can tell. When i swapped to another set of tubes it did start to fade out but i'll chalk that up to those used power tubes. The good pair sounded awesome, and then literally just goes silent, and returns if I continue to play for a bit.
Common causes?
Could a faulty pre amp cause this issue? I have yet to roll those pres as a solution, just getting ideas for when I start troubleshooting.
Thanks!
Common causes?
Thanks!
