Fender 65 Deluxe Reverb.....
  • Fender 65 Deluxe Reverb.....
    Customer wanted a complete retube....I noticed there is a tic tic sound when you activate the tremolo...Is this normal?? Just curious as I had heard that it is a quirk with some of these Fender amps.....the amp looks like a reissue........comments???
    Cheers
    P.S. I did do a quick search on this site but nothing there......
    Fender Amp Tremolo Mods
      Thanks Jazz.....I found a few on google as welll.......never saw this one.....
      Cheers
        Every one of these reissue amps I've seen has had the tick. Sometimes the mods don't work and there's still a residual noise.
          You would think that Fender would address this issue...after all they sell a ton of these....something else as well.....when switching in and out of standby, it makes an ugly loud pop......not impressive for the cost of a new amp..........
            That's the problem, right there. "We sell a ton of these, WHY change/improve them. Must be a perfect design, they're so popular."
            Does Fender still use a neon lamp in their vibrato bug? The neon discharge is often the cause of the audible vibrato click. I make my own bug with an LED instead, 99% of the time click becomes inaudible.
            You could disassemble Fender's bug, reuse their photocell and replace neon with a super-bright orange or yellow LED. Other colors might work but I haven't tried them.
              Anyone with a '65 reissue should be grateful they didn't buy a '68. Those things are so damn noisy from new I wonder how they got past the design stage.
                I think most of the "mods" to those "68 Custom Reissues" are stuff guys have been doing for a few decades now, which are possibly not the heat implemented solutions - usually in the name of "thickening distortion" or whatever. I seem to remember reading about at least a few in the Kendrick book... so, I'm not surprised they're a bit noisier than usual. Especially if one of those mode is a Neg. FB switch. My Bassman came with one ot those and was noisy as hell with it off. I could get the same sound by just turning the amp up louder.
                Justin
                  True that, I was both delighted and dismayed to find some of my standard mods in the "68 Deluxe." I'm very unimpressed about the way Fender joins the channels: simply "Y-corded" together, no mix resistors. Cheap and nasty. For an extra dime they could have done it right. Fooey on them!
                    Can you link a schematic? Only RI Deluxe Reverb I have on hand is 65 Deluxe reverb, which has 220k mixing resistors. I have no "68" drawings.
                      Two resistors cost 5 cents.
                      Skipping them, in 20000000 amplifiers, Fender can save:
                        Here's the service manual with schematic for the '68 reissue;
                        68_custom_deluxe_reverb.pdf
                        The problems with these amps is with unmodified amps, noisy from new. The reverb is especially noisy.
