Hiya all
I have a Fender Jazzmaster Ultralight with a faulty power amp board. It looks like someone has had a go at it already. The eight power mosfets mounted (in a horrible way) under the PCB have no insulation from the heatsink, all their tabs are connected together. They are all the same N-Channel IRFZ24N which do not have isolated tabs. This is a mystery because I cannot see how it would work with high side and low side devices with their drain terminals shorted. I will try Fender for a schematic. Has anyone worked on one of these before? Has someone substituted an incorrect mosfet then given up on the repair before I got it?
Thanks.
Thanks.
