Hi Guys.
I recently took in this amp for repair. I don't normally take on Mesa amps as I don't particularly like to work on them
Anyways, the amp works fine on both channels, but it has a nasty 100Hz hum. Pulling V1 doesn't help, BUT pulling V2 its gone!!
The LDR's 5&6 are good. Also the two gain pots are good and have returns to GND. I have checked the filter caps and all test good and I have no ripple after the choke. I even jumpered the capacitors with known good ones, but not even a slight change heard.
The heaters are balanced.
Replacing V2 doesn't help either.
I did notice that C12 is very sensitive to touch, increasing the level of hum. Replaced it, but no luck. Still loud hummmm.
Any ideas?
Any ideas?
