Schematic: http://music-electronics-forum.com/a...schematics.pdf
For reference, here's a similar topic: http://music-electronics-forum.com/t36001/
The power PCB is 170080.
I'm working on an Acoustic 125 for a friend which has low output. The schematic calls for injecting 140mV into the power amp and getting 10V out. I was getting closer to 2V out. (Test signal is 1kHz and the load is a pair of industrial heating pads that come to ~15 ohms.)
First I checked the DC on the board - the voltages on Q1 and Q2 were bad - wish I'd written them down, but I think the emitters and bases were measuring the same. All the resistors around them measured OK, so I replaced those with 2N3906 and the DC measurements fell in line. Output is now 3.6V with 140mV in.
The DC measurements around Q3 and Q4 seem fine. Q6's emitter is measuring 39V DC, while the schematic calls for 36V DC.
This amp was worked on about a year and a half ago (the previous tech left a sticker) and Q7 was replaced with a 2N5416 and clip-on heatsink. Q5 is still the original RCA 40409 with the original heat sink. Seems odd he'd only replace one. I'm tempted to contact him, but I'm guessing the work was done for a previous owner and it probably worked fine for some length of time after it left his shop so it doesn't really seem like it's his responsibility.
I'm assuming I should see something like 10VAC on Q5 and Q7, but it's just the 3.6V that's also on the output.
I don't know much about solid state amps, so I don't know what I should be looking for AC-wise. Clearly something's not making enough voltage gain, but I don't understand the schematic well enough to pick a culprit.
Any suggestions as to where I should start looking? Thanks.
