When engaging the eq switch, the sound gets very faint.
I've disconnected the ribbon cable with the eq slider pots (cn201 {located in the lower left section of schematic}) then engaging eq works, has the same sound either way. (If I'm correct, that means IC1-C{op amp 1 channel 3}) is working.
I tested the slider pots and they seem to be fine. 10k instead of 100k like schematic though?)
The 3 quad op amps (tl074cn) are getting + & - 15 volts.
I reflowed the solder for components in question.
What i notice is, the first 2 bands(op amp 1) cut in and out with noise and pops. Band 2 makes all sound silent when raised all the way up.
The next four bands (op amp 2) get hissy when raised above 0, but change tone.
The last four bands (op amp 3) are quiet but don't seem to change tone.
Does it seem like a bad op amp?
Is there a way to test them?
Could it still be the eq pcb?
I've heard of freeze spraying for shorts, and this sounds like a short??
Thanks for any help or insight.
