My buddy brought me this amp, a Pepco 201 series filament/widomaker amp. An amp tech added a 3 prong plug and bypassed the tube rectifier and simply put a single diode inline for rectification. My buddy claims that when he got it back from the tech a few years ago it had only a low hum which was acceptable to him. When he went to use it recently he found it is making a very loud hum rendering it unplayable. I plan on adding an isolation transformer but I'd like to deal with the hum problem first. If I disconnect the green mains ground wire from the chassis the hum goes away. This seems counter intuitive to me, I always thought that grounding the chassis would reduce hum, not exacerbate it. Is this a case of a ground loop?
On the other hand, if what he told me is correct, that it was working OK and then developed this problem, I suppose it might suggest a failing component that only manifests itself when the chassis is grounded. Does that make any sense? Any insight, suggestions etc. appreciated, thanks.
B
p.s. here's a schematic for an almost identical amp. The power tube is actually 50L6 and the wiring for the for the mains power section is a little different, probably changed around by the tech when the rectifier was replaced with the diode (see attached photo). I'm guessing that big ol' 400 ohm resistor was put in to drop the heater voltage that would have been dropped by the rectifier tube.
B
