If a transistor appears to be shorted, it needs to come out for testing further. But be aware, that when a part is shorted, there is nothing in the surrounding circuitry that can make it appear not shorted.
Gallien_Krueger 700 rb II short
Originally posted by hlynge View PostHow is it possible to remove the cooling grid from the heat sink. I have removed all screws and it is still solid stuck. Not moving at all. Any advice appreciated... That's $1.00 for the chalk mark and $49,999.00 for knowing where to put it!
That´s what I meant, including the prying tools pictures and warnings.
I always say that each Manufacturer has his own pet ideas which he applies all over the place; in this case GK has always made VERY compact and tightly packaged amplifiers which has made them famous.
Not *really* needed here where the head is roughly conventional size but they did it anyway.
You would have an easier task if repairing an equivalent Peavey or Hartke head, simply because of more available space.
Now some Ampeg ones are also tough to disassemble and reassemble, specially some SVT Pro versions.
What has been suggested so far is fine, you must identify power transistor pins which are accessible on the exposed (solder) side of PCB, and with no need of disassembly (yet) you can test for shorts between Base, Collector and Emitter legs (I assume they use Bipolar Transistors).
Use the Diode test setting, resistance scales are not very useful here.
If using a cheap Multimeter , you might want to sharpen probe tips, so they "bite" better on the solder pad you are making contact with.
Please measure and post results.
The main red flag being a short between any 2 transistor legs.Juan Manuel Fahey
I was not brave enough to start prying free the cooling paste so i tried to buy a replacement Gallien-Krueger 207-0250-B 700RB-II Replacement Amp Assembly from full compass. It has now arrived but it is still blowing fuses. Now I suspect that it is the trafo that has a short. it continues lighting up my voltage limiter tilll I pull the purple wire. What is the best way of testing a trafo ???
Kind regards Henrik Lynge
Originally posted by hlynge View Postit continues lighting up my voltage limiter tilll I pull the purple wire.
Locating a short in a power rail is time consuming and troublesome which usually winds up causing you to methodically remove components from the power rail one by one until the short disappears, or you can spot it with an infrared camera or see an evaporation pattern using alcohol, but this is all a bit futile when the fuse blows right off the bat... nothing has time to get hot... Fortunately you have a limiter so things can get hot without blowing the fuse. Use a multimeter and check the resistance between the purple wire and chassis ground, if it's zero ohms you got a rail short... then it's just the task of locating it, good luck!Last edited by Sowhat; 02-11-2018, 05:10 PM.... That's $1.00 for the chalk mark and $49,999.00 for knowing where to put it!
Is the purple on the primary or the secondary? The schematic in the link shows a violet wire on the primary. If that's the one, disconnecting it does not tell you anything.
To test the transformer, disconnect all the secondary wires and leave the primary connected. If the fuse does not blow, the transformer should be ok.
https://elektrotanya.com/gallien-kru.../download.htmlOriginally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostIs the purple on the primary or the secondary?
http://music-electronics-forum.com/t45285/
Maybe this can help.... That's $1.00 for the chalk mark and $49,999.00 for knowing where to put it!
I would tend to agree but the 700RBII schematic I linked shows the violet on the primary. pg. 25 of the PDF
No purple or violet shown on the secondary.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostI would tend to agree but the 700RBII schematic I linked shows the violet on the primary. pg. 25 of the PDF
Now that I see the 700RB schematic all that's being done there is disconnecting the mains with the purple wire, yeah, not very helpful in troubleshooting but sure saves fuses.
To disconnect the secondaries while leaving the primaries connected, unplug J20 which is the 7 pin molex between the big filter capacitors... oh yeah, and reconnect that purple wire (J15?).... That's $1.00 for the chalk mark and $49,999.00 for knowing where to put it!
Just a little follow up here... once you have J20 disconnected and J15 reconnected, power up with your limiter and if there's no or little glow your transformer is probably OK. If you pass this test, power off and reconnect J20 and then disconnect J8 which is the smaller 7 pin connector that powers the preamp... it will have wires going to the preamp, it's easy to spot. Power up again on the limiter and do the check, if you're still good (little glow if any) you have a short in the preamp, if not it's your brand new store bought amplifier module that has a short, and who knows what could be up with that?... That's $1.00 for the chalk mark and $49,999.00 for knowing where to put it!
Originally posted by hlynge View PostYes I am from denmark and the amp is wired to 230 V. Having disconnected J20 (Large white connector) and reconnecting J15 (violet led) results in a full glow on the limiter. What to try now.
Your help and guidance is highly appreciated
/Henrik lynge
[ATTACH=CONFIG]47055[/ATTACH]Last edited by Sowhat; 02-12-2018, 07:37 PM.... That's $1.00 for the chalk mark and $49,999.00 for knowing where to put it!
The board that I have got is of the series 206-0250-B2 and there is cable coloring printed on the board. This is what i have followed and I i have now confirmed that the cabling is correct according to the printed color coding on the board.
Is it possible that the switch can short-cut as this is the only component that seeem a litte questionable ???
I have heard some advise to you on this forum about the complexity of this piece of equipment for a novice, and they are very right about this however I applaud your tenacity with this issue. A power input forward approach is the way all of us should analyze a problem like this, and we do except for when we don't. This last test involving J20 should have been the most logical first step in this diagnosis after checking the fuse. Here however, it was the last.
Can't cry over spilled milk but it sure would have been nice to avoid the extra expense of a 700RB amplifier module plus a power transformer. On the other hand, nevetslab explained that these power transformers fail for a reason which usually lies in a failure in the amplifier module power section, so, maybe you have no choice on the matter here and maybe replacing it entirely with a new, good, used, working 700RB would have been the winning move.Last edited by Sowhat; 02-13-2018, 04:32 AM.... That's $1.00 for the chalk mark and $49,999.00 for knowing where to put it!
