the amp I have does not jive with any of the schematics ive found online.
(Polytone Schematics - Tube amp Schematics)
someone has definitely dug around in here before. first warning sign was that both output transistors had been replaced with 2n3055. I know occasionally youll run across a power amp that uses two NPNs but this amp has +30 and -30 rails and none of the polytone designs I've seen resemble a dual NPN thing. there was also a shorted driver. but before I dig too deep id love to see a schematic...
this amp has the proper To-3 heatsinks for the power amp. it says Polytone 102 70W on the back. its a 1x12 combo. the power amp pcb has a pair of NPN/PNP drivers for each output. currently they are 2n3053 and 2n4037s. other differences from existing schematics: rather than being .15 ohms, the resistors on the output are 15 ohms. and rather than being 100 ohms, the resistors on the bases of the output transistors are 2.2K
oh yeah and important detail: there is an 8 pin TO-5 old-style IC at the input of the power amp. unfortunately all the text has rubbed off of it....
I can post a pic soon - any thoughts in the meantime?
