Jazz Chorus amp chorus and vibrato not working. I think this is the 1984 model. I have opened it up and am looking for help. Trying to figure out what is what and can’t find a schematic. Any advice may help. Chorus and Vibrato might be very faint, not deep at all. It worked for years and years but would love to get it working again.
Roland JC-120 BB03539
Theses are the two JC120 schematics I have. Usually will get you close even if they're not exact as being worked on.
roland_jazz_chorus Schematic.pdf
Roland-JC120-JC160 Schematic.pdfLogic is an organized way of going wrong with confidence
Welcome to the forum! On the Chorus PCB, depending on which schematic you have that matches your PCB, if you have a scope, see if you have the appropriate waveforms for the Chorus and Vibrato signals on that dual IC that supports the dual Chorus chip set. I often find that IC (IC 5 on one schematic, IC 8 on the other) has failed for some reason. Not unheard of for one of the Chorus chips to fail, but not usually. And, of course, check the work you did when you had the PCB out. I assume your comment 'I'm having the same problem' refers to you not having Chorus or Vibrato function on your amp.Logic is an organized way of going wrong with confidence
JC120 Chorus Problem
Originally posted by nevetslab View PostWelcome to the forum! On the Chorus PCB, depending on which schematic you have that matches your PCB, if you have a scope, see if you have the appropriate waveforms for the Chorus and Vibrato signals on that dual IC that supports the dual Chorus chip set. I often find that IC (IC 5 on one schematic, IC 8 on the other) has failed for some reason. Not unheard of for one of the Chorus chips to fail, but not usually. And, of course, check the work you did when you had the PCB out. I assume your comment 'I'm having the same problem' refers to you not having Chorus or Vibrato function on your amp.
I'm not an electronics person, but can solder if necessary. I'll have to replace some pots since the shaft has broken off of three of them. It looks like I'll have to remove the circuit board completely to do that. Saving that project for the future.
Cheers
Jilly
