Hi all,
New to the forum. I just picked up an old Yamaha G50 112 for $50. Though I haven't tried it out yet, the previous owner tells me that it works fine except that when you turn the Q or frequency knobs of the parametric EQ section, the amp starts to squeal loudly, and the only solution is to turn the amp on and off. I'm OK with using the amp without the parametric EQ (especially for $50), but wouldn't mind troubleshooting it. I found a copy of the service manual online, and I see that there are couple of ICs in this part of the circuit. I know some of these parts can be hard to find now.
Any quick ideas as to what might be the cause of such an issue? My instinct tells me it's some kind of feedback loop, but beyond that I'm just guessing.
I know this isn't much info, but if any of you has any thoughts I would appreciate hearing them. Thanks!
Justin
Justin
