Want to say hello everyone glad to be here. I am looking for a tip where to begin tracks my down a loss of volume on channel 2 of my crate gt50 head. Recently,I was playing the amp and had a brain lapse I suppose and pulled v2 out while the amp was still on to switch to a different brand. When I put the new tube in and started playing there was a near total gain loss on channel 2. Channel 1 works as before the tube swap. I'm not sure where to begin to test for this change. The volume loss is almost total. Turning the channel 2 master volume near full gives a small sound though it does sound like the distortion character is like always. The v2 is used as a direct- coupled cathode follower tone stack on this amp as the gain is derived from an opamp/diode setup similar to a tube screamer or other distortion type pedal. After the tone stack, the signal goes through ss reverb and effects loop before entering a tube phase inverter. If anyone who didn't fall asleep reading this too long post could advise me what component(s) could result in this type of volume loss, it would be greatly appreciated as I have used this amp as bedroom practice amp for yrs with no issues. Thanks in advance.
Crate Stealth GT50 gain channel volume loss
Welcome to the place!
It's a good idea to post a schematic when you start a new thread, so here ya go.
http://music-electronics-forum.com/a...schematics.pdf"I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
First, I don't see you telling us you put the old tube back in - did we? Could be the new tube is bad.
Specific to your question,what component(s) could result in this type of volume loss
The way we do this is to apply a signal and ttrace it along through the channel. If the input goes through some common stages before it branches, we know those parts work because the other channel works. SO we can limit our search to the channel specific circuits.
Does V2 have good plate voltages on 1 and 6? Are there cathode voltages on 3 and 8? I see three op amps in the circuit, are pins 1 and 7 on each free of DC? Are they showing signal?Education is what you're left with after you have forgotten what you have learned.
I appreciate ONE of the responses I received. Of course I put the old tube back in as well as tried several others with same result. Didn't post the schem because I don't have the internet at home and borrowed a friends phone to put up the post. Was really just wondering if removing that specific tube was a definite no-no or else 'this happens' kinda thing, but really just got reminded why I stopped using forums ten yrs ago. Obviously, it still holds true that if you want kindness or common decency and not belittlement from some... you still have to pay for it. I'll take the amp to a shop when I save up and just use channel one for now and a pedal.
