Having recently dug out my Mesa Stereo Simul-Class 2-90 Power Amp to have a fresh look at it, I found while looking at the output of the amp driving a matching resistive load, that the voicing filters (Deep and Modern) didn’t seem to respond much on the audio analyzer. Yet, when driving my Ampeg BXE-115HL4 test speaker with pink noise, it clearly made a lot more difference. Manually sweeping my oscillator in the low frequency range, I was seeing a lot more output. But of course I would! It’s a transformer-coupled amp, ya dummy!
I haven’t yet set up to run an impedance plot of the test speaker, but, just to see the difference, I set up my simple Vellman PCSGU250 Bode Plotter, using my Amber 3501a Audio Analyzer to receive the amp output and a HP 353A transformer-coupled Step Attenuator for control of the generator’s output, I proceeded to generate Frequency response plots showing the baseline 4 ohm Resistive load plot , first showing the two Voicing Filters (Deep & Modern), and the Min, 50% and Max settings of the Presence Control on this amp.
Then, I ran the same baseline plot of 4 ohm Resistive @ 50% Presence and added the response plots with the Test Speaker attached. What a world of difference that shows!
For example, when I added the Deep Voicing Filter, the LF output where the speaker hits maximum impedance at around 65Hz, the output is 15dB above the 4 ohm resistive load level. The Presence range, which is now boosting in the HF region where the inductive reactance of the speaker is again high impedance, it’s a good 12dB up from the baseline.
That old comment stating that tube amps just seem to sound louder than solid state amps….I’d say so. The results are certainly more dramatic under speaker drive conditions than it is driving a dummy load.
Pardon my typo's in the annotation of the graphs. No simple way to recover from that.
