Bugera 1960 half volume?
  • #31
    Not a terribly helpful reply, but my friend gave me a non-infinium 1960 that had bounced between all the techs in the northwest, who declared the amp had no fault, despite producing nearly no power and redplating the tubes. I had a poke around and all the voltages seemed sensible. I was going to test the OT with a neon but I instead have opted to pull all the PCBs out and build something else in it with a spare OT I have.
    • #32
      So did you try the other transformer to see if that was it?
      • #33
        Removed the feedback wire... Still have
        ~237k ohms between the primary and secondary...
        • #34
          It was the output transformer... Got one from eBay for $40... Worked perfectly... After reading several posts with extremely similar faults, and after troubleshooting everything else and finding no fault I deduced that it to be the output transformer...
          • #35
            I also want to thank each and every one of you that helped me.... All of the knowledge here is worth so much... I appreciate all of you...
