Yep. Another thread haha.
Well. I've tirelessly been at this thing for 2 days now. It wouldn't switch channels at all at first. Replaced U3 and it started switching. But no MORE DRIVE. I've gone thru the voltage test points at least 5 times. Everything looks good EXCEPT:
TP34 pin3
-12v
-11.7
-11.7
TP36 pin1
-15v
-15v
-15v
I replaced Q4 because it seemed that it should be turning OFF when pin7 goes low. Replacing it didn't help. Same readings. Replaced U3 again thinking maybe I blew it probing around. Then I replaced Q4 again because still same readings.
I cannot for the life of me figure out why Q4 has the same -12v on C and E. I replaced it with mps6531 NPN 40v 600ma just like the 2n4401. Same leads too.
Again. All other test points are correct.
Baffled. Circuit board says 2002 fyi. So I think this is the right one. http://www.thetubestore.com/lib/thet...-Schematic.pdf
TP34 pin3
-12v
-11.7
-11.7
TP36 pin1
-15v
-15v
-15v
