Hi,
I am working on an HA3500 with a clean output up to more or less 50W output. After that, the top side of the signal clips (under load). I have checked the output transistors, the ballast resistors and even tried to change the driver but no change. the voltage rails are steady, even under clipping condition. Without a load, the output is clean all the way. I should mention that the input signal is a clean sine wave. here is a pic of the output on a scope:
The HA3500 is available in many posts on this forum.
Any ideas?
Any ideas?
