Hey All!
I've read through all the threads multiple times and have picked up a few ways to figure this one out.
The amp switching does not work. LED does not light at all. Master volume, reverb and channel switch all have no effect when knobs are turned or button is pressed.
The previous owner swapped R78 and R79 for 5W 300ohm resistors (as indicated on the schematic I found). This did not fix the issue. These test as 330ohms with my mulitmeter. A lot of other posts mention -16.6v and -16.6v is the voltages you want to see when testing the resistors. With the amp on I get -15.7v on r79. nothing on r78.
I checked for continuity to make sure the resistors are making connection to the board and everything tests OK. even though the trace to D13 from r78 looks scratched.
On the other side of the resistors where the connect to the caps
-32.6v R79
+30v R78
I checked the dual LED and both sides light up.
What's next?
Thanks in advance. This forum is an amazing asset and I have learned so much.
EDIT: Here's a pic of the resistors. Could the color mismatch on the ink suggest anything?
-32.6v R79
+30v R78
What's next?
