at 240VAC no tubes filament voltage is 6.8
hum balance is dead center
setting the bias to .038 allows for a clean output of 4VAC into 4 Ohms, or a bit off the normal 220 Watts or so!
at this point, the PI is outputting cleanly and delivering 19VAC-- without the output tubes installed they deliver up 63VAC clean and reasonably well balanced (within 5%)
continuity check on output jacks made early on and now repeated
the 22 Ohm resistors and diodes were replaced with 220 Ohm early on
no 5Watt plate resistors on this model, it uses ferrite beads.
putting 220VAC across the primary of the OT gives 7.7VAC on the 2Ohm tap which works out to around a 1625r load. That seems about right too and with no strange current load.
Thanks again for all the replies, I am very curious how this one will end up.
