The dreaded jcm 2000 ..... This is the 401 with el84s. Have a big short or current draw . Not the tubes...but only does it with the el84s in (new ones and the old set) , If i pull the heater fuse F4 , for the el84s and PI , it goes away . R34 / 35 test good.
I measured the resistance of the secondary of the PT with nothing hooked up to it -
HT pins = 36 ohms
Bias pins = 10 ohms
Fil. pins = short / 0.0 ohms
that filament winding shouldnt measure 0 right ??
http://www.thetubestore.com/lib/thet...-Schematic.pdf
HT pins = 36 ohms
Bias pins = 10 ohms
