Ampeg SVT 7 Pro cuts out with vibration
  • Ampeg SVT 7 Pro cuts out with vibration
    Follow up to my earlier post. http://music-electronics-forum.com/t44766/
    Power now seems pretty good, but still cuts out (goes silent for a second or two) at high volume. Finally found out that it is happening when it gets some vibration or mechanical shock. It happens when the head is sitting on the bass cab, but not if it is isolated from the vibration. It also happens if you pick up the head and set it back down somewhat roughly. I am suspecting a cracked solder joint, maybe on a FET or torroid/transformer, I think the heat sinks for FETs are supported only by the FETS themselves, so maybe a weak spot. I opened it up and did a (gentle) tap test of the larger physical components with a drumstick and was not able to reproduce the problem.
    The headphone output does not cut out, so I believe the preamp section is good.
    My next thought was to just inspect the solder joints of all the through hole devices, or maybe just reflow all the larger ones. Any other ideas?
    Thanks,
    Greg
    schematics:
    my money is on solder joints.
    is anything getting hotter than it should be?
      The only part ever getting hot was the SMPS chip that I replaced (twice), and added a heatsink to.
        Oh, I also ran a jumper cable from the preamp out to the poweramp in to rule out flaky switchjacks.
          Got a chance to look at this one again today. Put the scope leads onto the power FET legs while recreating the problem. The voltage rails were solid but the switching drive to the FETs disappears completely when the sound drops out. Got out my drumstick again and was tapping on components related to the switching signal. Sound cut out when I tapped on U300 chip. Will probably try to reflow the leads before I replace it. I know that working on SMT is not as hard as it seems, but I can't say I am looking forward to it. Maybe need to get my big magnifier light out. I have some scrap SMT devices I will practice on too.
          SVT 7_ Main Bd.pdf
