Came in with a shorted power transistor. I removed both and added 1k B-E resistors. The drivers have good Vbe at +/-600mv and with bias pot full cold (Q4 fully ON) I have about 300mv across the 1k on both sides.
I've already been thru this process once. Then I installed the power transistors and my limiter bulb glowed brightly and both power transistors shorted completely. All pins of each!
So back to the 1k installed. Everything looks as before... however...does Vbe of drivers to common (ground) matter? I have -1.1v Vb on Q5 driver and +550mv Vb on Q6 driver.
