I want to measure the power output of two SS amps, a Crate Power Block, and a 7-watt Rolls amp, into 4- and 16-ohm resistive loads.
I've done this a million times on tube amps, but I'm having trouble with the SS amps. As I turn up the volume with 1KHz sine applied to input, I get nothing on the output until some wild oscillation happens. Same on both SS amps. Swapped in my 10-watt tube amp, and all looks OK again.
I decided to use my $30 DSO Shell scope instead of my Hantek, and I see the signal now! Next, I hook both probes to the output, and it works...sometimes. There's something causing the SS amps to misbehave unless the DSO Shell or an actual speaker is attached.
What's going on here?
