Supro Bantam No.11
  • Supro Bantam No.11
    This is the last of the vintage amps I need to put a grounded plug on , I have a Triad N-68X isolation transformer that I plan on using , would appreciate some guidance on doing this the right way. The schematic is as close as I've found for this amp. I mounted a fuse holder and the iso on a 1x3 board , ran hot to fuse out to the iso , direct connected neutral and grnd to iso, out from iso hot to fuse in the amp where the original line connected , neutral to the switch , grnd to chassis ,making no other changes. Is there a better way ?? Replacing filter cap , and the .05 MFD caps any suggestions on the best replacement caps for the .05's , I have some orange drops.
ID:	873391Click image for larger version
Name:	Supro Bantam .JPG
    If you don't know where your going any road'll take you there : George Harrison
