I have a Vox AC30-CC2X on the bench with no Reverb Signal return. I had found the high voltage MosFET Q102 type LND150N3 wasn’t passing signal. The Drain voltage was 276VDC and the Source voltage being 0.71V. Injecting signal by way of the Return RCA jack to it’s gate got there, but no signal on the Drain. Powered down, the gate measured 70 ohms to ground. Ordered parts, installed a fresh one when they arrived.
With the signal fed into the amp, I still had no Reverb. So, in checking the return path, I had signal passing thru it, though the level seemed quite low. After looking at the schematics, the signal from Q102 passes up to the Reverb level and tone circuit by way of a ribbon cable, then comes back to the Reverb PCB and is routed to Ch B of IC103, a 2120D Dual Op Amp…switched part like that 5201 IC used on Marshall amps. I wasn’t seeing signal at the input @ Pin 7.
I unplugged the ribbon cable, and jumpered the send/return pins to bypass the Reverb pots, and now I had signal at Pin 7 of the 2120 IC. But, no signal on Pin 5, which is the common output of the two op amps. Pin 1 is the control voltage port on this op amp. I had 12VDC with no foot switch plugged in. With the F/S plugged in, Pin 1 would change from 15VDC to 12VDC. No output signal in either case.
I swapped out the 2120 for a new one, but with the same results. Then, I swapped out the switching transistor Q103, being a 2SC2910 hi voltage med hfe part. Closest I had to it was a BF422 and tried that. No change….still no output from IC, with Q103 switching fully on and off. The output from the 2120 is DC coupled to the summing input of IC1B (a 2147 hi voltage IC via 56k summing input resistor). The Switching IC 2120 is running at unity gain, so there certainly needs to be a lot of gain on Q102, which I don’t see.either. I checked to see what the DCR was at the gate of Q102, and it was 220k, the resistance of R125, which before was sitting at 70 ohms. That had to have been the Reverb tank misconnected by the client, who replaced the tank. I had DCR of 220 ohms and 70 0hms, so the 70 ohms would be the input and 220 ohms the output. That would explain why I had seen 70 ohms before.
I have plenty of signal driving the tank, just have no gain or signal thru the return path. I do see the traditional low level signal coming thru the tank.
I swapped IC103 again, but still no signal passing thru it. Also, with the Reverb controls plugged in via ribbon cable, the signal level from Q102 MosFET is loaded down, so I still have to get to the bottom of that. First time I’ve encountered this problem on one of these Vox amps.
LND150-N3.pdf
NJM2120_E_sub for M5201 Marshall Dual.pdf
Vox AC30-CC2X Sch 1.pdf
Vox AC30-CC2X Sch 2.pdf
LND150-N3.pdf
