Late 70's Vibrosonic Reverb issues
      Zip it.
      Fender Tech Notes - Vibrato Ticking Fix.zip
      Here try this.
      nosaj
        Yes, that is the one, I have no idea why mine won't open. And no idea why adding my sig to the file blanks it. I have added to schematics many many times.
          jason, it works. thanks.
            Okay I am stumped.
            Below is a shot of my scope. The top distorted wave is from the output of the amp using the Vibrato channel. The bottom wave is from the output of V2b. The wave distorts when the volume control is turned past 4. All of the tone controls are on 5. The master volume is on 3.
            With the Normal Channel I have to "dime" all the controls before the sine wave even slightly deforms.
            I checked the tone and coupling capacitors and they all appear to be fine.
            Any ideas?
              Any ideas why this website likes to rotate my pictures?
                You are good at V2B, after that it goes through V4B, which the clean channel does not. How does the signal look at the output of V4B?
Name:	waves_ rotated.jpg
                    At the grid and plate of V4b the sine wave has the top portion of the wave slightly squared off.
                      Is the master volume switch stuck "on"? That boost would bleed into V4B grid, I think.
                      Other wise, what voltage level of signal are you putting in, and how much is there at V4B grid? 4 on the volume sounds kind of hot, it would be better to try with master full and ch.vol lower.
                        The plot thickens......
                        When I pull out the master volume boost knob the sine wave output reduces in height (volume).
                        Now I am really stumped!
                        • #27
                          Maybe it's wired backwards...
                          Okay, I didn't read the whole thread again, but it just kinda seems like it. With It in it's distorted and louder, but out its quieter? Is it still distorted (by ears, not scope)?
                          Justin
                          • #28
                            The switch is a double pole single throw so it cannot be wired backwards. It is either on or off.
                            Well I gave up and took the amp to a friend who repairs amps for a living. He checked it over with me present and said that it was working correctly. Boy do I feel like a dope.
                            • #29
                              Better to feel like a dope and have a working amp than to feel real smart and have an amp that doesn't work?
                              As to the switch, apparently it is OK, but don't take backwards too literally. A DPST has four terminals, and do a 180 and it works out the same. But if you wire it 90 degrees off. PFFFFT.
