Hi all,
can someone clarify which power supply configuration is this and does it really put 745VDC on output transformer CT?
If that voltage really ends up on EL34 anodes, which of the current production ones can take it? Or is it just a matter of keeping the screen voltage under max specs (which it does, 395VDC per schematic).
I guess if that anode voltage is too extreme, the supply could be split to provide 420ish VDC for OT CT?
The whole schematic is linked below:
http://music-electronics-forum.com/a...88-or200-2.pdf
Thanks.
Thanks.
