If anyone has a schematic for a Laney AOR 20, please let me know. I have a friend that asked me to look at his amp. He replaced the electrolytic capacitors, and used it for about a year, then it started acting strange. When I play a low E string, the amp makes a garble noise. Thanks
Need Schematic for Laney AOR 20
Originally posted by CoopDaKill View PostIf anyone has a schematic for a Laney AOR 20, please let me know. I have a friend that asked me to look at his amp. He replaced the electrolytic capacitors, and used it for about a year, then it started acting strange. When I play a low E string, the amp makes a garble noise. Thanks
nosajsoldering stuff that's broken, breaking stuff that works, Yeah!
I emailed Laney, and the replied stating they had no knowledge of them ever making a 20 watt AOR. But I have a pdf file of the user manual showing the 20 watt, 50 watt, and 100 watt models.
Anyway, I fixed the amp. The owner had installed 1ohm resistors from pins 8 & 9 of the output tubes, to the chassis ground ( to Check bias, he said). I found out this was the problem by taking voltage readings. When I touched the positive meter probe to one of those 1 ohm resistors, the amp became quite. I strummed the strings and it sounded great. The resistors measured fine, out of circuit. I replaced them with solid core wire. So, with my lack of technical knowledge, I guess the design of this amp wouldn’t allow any resistance to ground from those 6V6gt output tubes (pins 8&9)?
Originally posted by CoopDaKill View PostI emailed Laney, and the replied stating they had no knowledge of them ever making a 20 watt AOR. But I have a pdf file of the user manual showing the 20 watt, 50 watt, and 100 watt models.
Glad you got it working.
nosajhttps://www.creamcitymusic.com/1987-...ube-combo-amp/soldering stuff that's broken, breaking stuff that works, Yeah!
Anyway, I fixed the amp. The owner had installed 1ohm resistors from pins 8 & 9 of the output tubes, to the chassis ground ( to Check bias, he said). I found out this was the problem by taking voltage readings. When I touched the positive meter probe to one of those 1 ohm resistors, the amp became quite. I strummed the strings and it sounded great. The resistors measured fine, out of circuit. I replaced them with solid core wire. So, with my lack of technical knowledge, I guess the design of this amp wouldn’t allow any resistance to ground from those 6V6gt output tubes (pins 8&9)?"I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
Um... where is pin 9 on a 6V6?
A 1 ohm or 10 ohm resistor from pin 8 to ground would not affect the amp. Unless the amp was cathode biased originally.Education is what you're left with after you have forgotten what you have learned.
