Fender twin weird distortion/cracking when I pick a hard note
  • Fender twin weird distortion/cracking when I pick a hard note
    I'"ve got a 73/74 fender twin. New output tubes and newish preamp tubes that work perfectly in my silverface super.
    Doghouse caps replaced along with the 470 ohm screen resistors. Bias is set at 25 ma
    This happens no matter where the volume (s) are. If I play medium soft it sounds great but when I really dig in I get a crackling gritty distortion sound. This happens on both channels. I've subbed in different speakers and that is not it. As it is on both channels I'm assuming Its in the PI circuit or the Power tubes circuit. Short of replacing all the resistors , any thoughts on where to go looking or how to test? If I get a chance I will post and audio clip of the distortion. I have owned a lot of tube fender amps and never had one sound like this. Frustrating because apart from that its a pretty decent twin
    TIA
    Brian
    A link to the relevant schematic would be nice.
    Failing that, what features does your model have, eg master vol, pull boost?
    Have you tried plugging the amp chassis into a different cab?
      Its a Master volume 100 watt. Date stamp on chassis says 1973. The Master amp pull circuit has been removed, not by me. Dave Vidal of Vancouver Worked on the amp a few years back. Yes I tried different speakers. No joy there.
        Is it this one?
        http://vintageampguide.com/schematic..._100_schem.jpg
        If it is. Voltages are handily labeled on the schematic. I'd start by measuring voltages on plates and cathodes and see if there is anything substantially off. Voltages will not match "exactly".
          Do the Volume pots sound gritty when you turn them? I've had weird distortion on Fender Twins, Deluxe, others having that front panel PCB where all the pots are mounted to the common PCB. Cleaning the pots, or in a couple cases, replacing them cured it of that. Also the input jacks, though not so on the old amps where all that is hand wired. Most of what rols thru the shop are the re-issues.
          If you have a scope, try probing down the signal path to see if it's a particular stage introducing the problem.
            Without a lot of information about the history of the amp, we're forced to shoot in the dark. You've told us that some tubes have been replaced, but you haven't said anything else about what's original and what's been serviced. Are all of the caps original? Electrolytic and coupling? Have any resistors been changed? That's important information to know.
            Like Dude says, a voltage table with AC and DC voltages listed on the pins would be helpful. When working on a 100W Twin Reverb, I think that looking at the Reissue Service Manual is often helpful, as it gives you additional test point voltages and testing parameters.
            FWIW, when I hear that there's crackling on the edge of a signal, I think coupling cap. If it's occurring in both channels, then I'd be looking downstream from the mixing resistors. When I hear intermittent crackling when no knobs are being turned, I first think of screen resistors. But I always look at voltages first.
              Since this is your first forum post, I'm going to assume that it might help to provide a link to RG's Debugging Guide:
              Popping is almost always an arcing problem. The high voltage in the amp has found some path that cannot stand the high voltages and discharges suddenly through that path. The arc current is high, but cannot be sustained by the power supply, so the voltage drops a little, the arc extinguishes, and it takes some time for the power supply voltage to build back up to where the arc will start again.
              Popping is often associated with the time when you flip the standby switch. In standby, the current drain from the power supply is less, so the voltage rises, causing more voltage stress. When the standby switch is thrown, the higher-than-normal voltage can break over things that stand the normal stress of operating voltage.
              Tubes
              The tubes themselves will sometimes develop internal, intermittent arcs. Do some tube swapping. Start at the front (preamp) end of the amp and pull a tube, listen, pull a tube, listen. When you find one where pulling it makes the popping stop and a new tube makes it quit completely, you're done.
              Arcing power tube socket
              The B+ may be arcing across the surfaces of the output tube sockets themselves. This is often the case when an amplifier has a lot of dust and dirt inside it. In some cases, the arc can be started by a few seconds of playing without a load on the amp, which causes large spikes on the plates of the output tubes. Contamination of the tube socket surface can let an arc get started, and the arc itself burns the surface of a plastic tube socket body. This leaves a carbon residue in the path of the arc, burned remains of the trail of the arc; the carbon residue is itself somewhat conductive, so in the future, there is a ready made path for the next arc. You have to replace the socket if this is the case.
              Intermittent switch
              A switch, often the standby switch, can develop internal arcs
              Intermittent breakdown of coupling cap or a popping resistor
              Sometimes a signal coupling capacitor just can't take it anymore, and it starts breaking down intermittently. Resistors, particularly those delightful, brown sound carbon composition ones, sometimes develop internal pops. Proceed as for tubes. In this case, a new replacement tube will NOT make the noise quit permanently, and you have to figure out which component is causing it.
              Intermittent breakdown of output transformer or choke
              The filter choke, if your amp has one, and output transformer are connected to the highest voltages in the amp. If they are old (can you say "vintage"? I thought you could) and if they get hot, the insulation on the wires inside can start being intermittent. Internal shorts that clear will cause popping. Shorts that don't clear will pop a fuse, usually. Sometimes it'll just cause smoke.
              broken resistor or capacitor or R/C lead/ wire
              This is one where the problem is not caused from the B+ breaking down insulation. Mechanical damage can break a part and leave enough pressure on the pieces so it mostly makes contact and kind of functions. Vibration will cause it to open momentarily, causing a pop.
              Heat from resistor or output tube melting solder
              This is a fun one. Some of the power supply dropping resistors, output tube cathode biasing resistors or the connections on the output tube sockets themselves get so hot that they melt the solder that attaches the leads. Even more interesting is when they just soften it so it gets grainy and any vibration (speakers, anyone?) makes a cold, grainy solder joint. This bad joint can pop and arc, sputter, hiss, rectify AM radio, do lots of nead stuff. Once you find the bad joint, you'll also have to find out why it was so hot.
              You can sometimes leave the amplifier turned on and turn out or dim the lights in your workroom, and see arcing happining. On pops that happen when the amplifier is touched or jarred, you can (gently, now) tap the chassis with a rubber hammer or wooden stick, being careful not to break anything or touch the amplifier with your hands as you do this. This often makes a mechanically-motivated arc happen, and you can see where it is, and deal with it when the lights are on. BE VERY CAREFUL NOT TO TOUCH THE INSIDES OF THE AMP IN THE DARK - THE HAZARDOUS VOLTAGES ARE JUST AS DANGEROUS IN THE DARK.
                I've had something similar on a couple of Twin 65RI right out of the box. The problem went away if the reverb tank was unplugged or the reverb driver tube was pulled. Defective reverb driver transformer? Dunno, as we just sent them back for replacements.
                  Looking at your avatar I can't help but think that somebody's got the Les Paul Fever. And a really bad case, at that.
