working on an orange TH-30 . It has 2 of the el84s red plating , the other 2 do not. Its not the tubes .
Looking at the scem , ive checked all resistors from V5 all the way to pin 2 of the el84s , ground is good , no bad solder joints , and while i had the pcb up i replaced the .1 caps , c45 / 46 coming out of V5 .
with no el84s installed im getting 280vdc at pin 2 of V 6 /7
at V8 / 9 , i get about 0 to 4mv..the meter just kind of jumps around--it wont settle down on a number .
Any thoughts ??
TP13 is 290vdc at "C" so that looks ok according to the scem.
Any thoughts ??
