Hi all first post here. It looks like there is some pretty sharp minds here. I have been reading the other Marantz 18 thread and it looks like a few of you have a good knowledge of the amp section. Mine has a turn on hum in the right channel for about five seconds. DC on that speaker goes up to around 6.5 volts. Then the relay opens and closes DC goes near 0 and audio plays fine. Poking around the amp and driver I have found that Q2 C goes to ~+7 volts then to +1.5 volts, E goes to ~+6 volts then -1.5 volts and B goes to ~+5.5 volts then to -.6 volts. Before I bought the unit Q10 was replaced with SK3083 and Q14 was replaced with SK3027. The problem was still there with the outputs removed. Any ideas of what to look at would be a big help.
Thanks
Tony
amp page.pdf
Thanks
Tony
amp page.pdf
