A 2011 version Delta Blues. I think it is a redesign of the truly awful three board sandwich nightmare. Anyway, it went up in smoke on stage. I can't find a schematic, but the 1K 5w screen resistor on one of the EL84s got real hot and charred the board real good. It now reads 646 ohms, and has signs of distress. OT passes the neon test, and I find nothing else amiss. My first inclination is the tube shorted, but it doesn't look that way on my recently acquired military surpluss Hickok tester. I mention I just got it because I cannot confirm I have ever seen it detect a short before, so there is that. PLus, the tubes all look very similar and good in the other tests.
So, what to think here? Bad tube or how likely is it that resistor just started to fail and caused the heat issue? I usually expect a resistor to fail by increasing in value, not decreasing.
