Greetings, solder addicts,
This should probably be 2 threads, so I'll get to the Peavey later...
The Fender came in with a 'no reverb' complaint, here is what I've checked -
Accutronics 4AB3C1B tank - input 1 ohm, output 200 ohms, cables are good (& in the right place I think, white input red output)
Ran a 1000hz 3mv signal in, crazy loud 'sproing' if I tap the tank, so output seems good.
Checked the 12ax7 & 12at7 which are next to reverb trans, OK
Checked reverb trans - black/green secondary reads 1.2 ohms, blue/red primary is 1.065K (spec I read somewhere here said 1.9K... ?
Checked output AC voltage at input to tank - ziltch -
Interesting arrangement on the 12at7 - pins 1&6 are tied, as are 2&7, 3&8 and 4&5... so plates, grids, cathodes & heater (according to the 1953 GE data sheet)
Does that mean the 2 triodes are working together?
What do I look for now?![Confused](https://music-electronics-forum.com/core/images/smilies/confused.png)
P.S. found the main board attached by only 2 of 6 original screws, one of which was broken off & stuck in the chassis (gorilla must have over-tourqed it). A little Dremel, drill & 6/32 tap and board is now as Leo would have liked it. I'm better at mechanics than electronics - but you guys already know that.![Stick Out Tongue](https://music-electronics-forum.com/core/images/smilies/tongue.png)
Waiting on your wisdom,
Lorne
Lorne
