A friend bought one of these for almost nothing because it wouldn't power on, then brought it by for me to check out. Traced the short to the bias circuit, secondary produces ~400vDC on the LBL. Tested the OT and it's still good, so this should be a straight forward service/repair situation, except I have never seen a Bandmaster TFL5005D before and want to run it by the pros before jumping in feet first. One thing that struck me as odd was the power tube arrangement.
Main power switch was changed at some point as well as the 100 ohm center tap resistors for the heater circuit. Lots of goop inside in several places.
Here is the plan with amp on light bulb limiter and auto-transformer:
For those with experience with this specific model, I'd appreciate any caveats, gotcha warnings, and solid advice you might have before I move forward. I'll likely start the repairs in a week or two, so in the meantime I'll be seeking information.
EDIT TO ADD: The attached schematic shows a much simpler bias arrangement and only two 6L6GC power tubes, yet it is labeled TFL5005D. Anyone have any information that would clear that up?
EVEN MORE CONFUSED NOW: The printing at the speaker output reads 40 watts! But there are clearly four 6L6GC power tubes, and it doesn't indicate minimum impedance load
OK, does anyone here know what I have here?
- Repair bias circuit to remove secondary shorting condition, stabilize amp, THEN:
- Change every electrolytic cap in the amp
- Install grounded power cord, remove death cap, wire to current standards
- Streamline the bias circuit, wire to BF convention
