Hi;
Recently a friend of my gave me his old Tubeworks RT-300 stored for quite some years. The amp turns on without a problem, but have pretty low volume for a 300W amp; I have a 50W Peavey amp and sounds much louder than the Tubeworks.
Checking the internals found that the PCB had some routes fixed in the past( the fixes look correct to the schematic), most of the components test well with my DMM, what notice a little strange is that the transformer secondaries deliver 97 ACV to the power stage, but in the diode rectifier convert to +/- 65DCV to the power rails K135 and J50. Tested the Preamp section with a signal tracer and there's no drop of signal in the different control pots neither the EFX send/receive, so I keep the four A2D 6A4 diodes of the rectifier suspects even when tested good for short or open.
Does anyone have some experience with old Tubeworks similar to this or maybe have some ideas where I can check to repair the low volume problem?
