(3)12ax7 (2)6L6 GZ34. original condition. head only
the owner is an old friend.got this from a guitar player that used power soak devices. 6L6 version. first visit- shorted section of 50uf 600v B+ cap before T3 and shorted rectifier tube. replaced both dual 50uf caps with F&T 500vdc and JJ GZ34 rectifier tube. owner comes in a month later.got to a gig with crappy line power.amp began distorting badly.fuse blew after he tried to jumper ch1 into ch2. Now as soon as you turn on standby switch 500ma HT fuse goes...with only the rectifier tube installed. replaced with known good rectifier tube...same issue. with only rectifier tube installed, disconnected yellow wire from 50uf cap(it carries B+ to plates of preamp tubes)...HT fuse doesn't blow. normal heater voltage, 417vdc to plates.I also see 417vdc on plates of empty preamp tube sockets but thats coming in from T3 which is still tied to B+ of other section of 50uf cap.. this device labeled T3 on schematic is not a conventional choke like what is seen on the outside chassis of most jtm's mounted near the output tranny. this is inside and looks like a miniature dummy resistance load.gold appearance. 100R stamped on it.ohms out at 100 ohms.inserted between the positive terminals of first 50uf / 500volt cap. output tranny ohms out at 75 and 73 ohms to center tap.looks like bias circuit gets power from mains switch before standby switch. I did measure both dual 50uf caps just to be sure and they checked out.sorry to be so long winded about this thing.thanks for your opinions.
