Hi - I have an Acoustic 470 that I am working on. I received it in very poor condition. It had intermittent output, scratchy pots and tremolo not working.
Sprayed the pots a few times and got volume and tone controls and reverb. So after reading about some of the symptoms I saw; a recap of the boards was done.
Current state: The amp works and is loud and sounds very good. Reverb and Trem work great.
The remaining problem: When I turn on the distortion circuit using the Distortion knob, there is no output (as if the signal is grounded).
If I turn off the distortion (via the knob), them amp works great.
I checked the switch and it is working (makes sense as it changes the behavior of the amp).
I was looking in the area of Q103, Q104 and Q105 and diodes D101 and D102.
I don't fully understand their distortion circuit using the 1n914 diodes and the 2 FETs. I checked the 2 1N914 diodes and the N channel FET (2N5457) that are OK.
What is the purpose of the path from C107 to R125?
Am I looking in the correct circuit location? Any ideas on how to proceeds for here?
Also - Suggested replacements for the 2N4360 transistors? The 2N5460 looks good but I believe the pin/leg configurations are different.
2N4360 (S-D-G) and the 2N5460 is (D-S-G)
So close - yet so far!
Thanks
Acoustic 470 Service Manual.pdf
Thanks
