I just put new 6L6's and a new GZ34 rectifier in a 1972 Pro Reverb. The GZ34 replaces a weak 5U4GB. The tube chart indicates a 5U4 rectifier but does not specify a circuit number. As far as I can tell, for all intents and purposes the circuit is the AB668 as it is a 1972 silverface with no mid knob. Anyway, those details may be neither here nor there. What I'm concerned about is the voltage readings I am getting for B+, plate, screen etc. The voltages seems to continually fluctuate, from between 1 or 2 volts to as much as + or - 5V, making it hard to determine if the screen voltage is below the plate voltage. So, two questions. 1. Does this indicate a potential problem with the rectifier or possibly the power transformer? 2. If I know the screen resistors are good can I safely assume the screen voltage is below the plate voltage at a any given time? The 6L6's that were replaced show evidence of excessive heat. I initially assumed they were biased too hot but now I'm wondering if the screen voltage might have been a problem. The original 1 watt screen resistors appear to be fine, they read a little higher than 470 ohms but within tolerance.
B.
B.
