I have a JCM2000 missing some cables. No luck searching online for a source to buy them. Anyone advise?
Looking for the following cables
2 pin that connects reverb board CON1 to main board CON8
2 pin that connects reverb board CON2 to preamp board CON8
3 pin that connects reverb board CON3 to output board CON4
2 pin that connects main board CON7 to preamp board CON9
These were removed to eliminate the reverb and the effects loop.
I would at least like to get the effects loop working again. Looks like that is the 3 pin cable. Not sure the other cables are needed to complete the effect loop. The effect loop is eluding me in the attached schematic.
Thank you!
Thank you!
