Schematic question
  • Schematic question
    Can someone have a look at this scem ? I was told there was a thermistor in here that will turn the 2 fans on and off. I dont see one...unless the LM7824 is used somehow ..but isnt that a voltage reg. ? Page 2 .
    Just curious !
    What's this thingy on the fan circuit labeled 9L122uh below. Never seen that component symbol before. There's another on the power switch without a moniker.
      I don't see it. It could be there, but I don't see it. I believe it's probably hooked between J18-1 and J18-2 on the schematic and probably mounted on a heat sink. Those 2 points are to the right of the LM7824 on the schematic.
        Maybe coils for EMI supression?
          thought ferrite bead ??
            The thermal switch connections are marked as the Dude said.
            (the switches themselves are not shown))
            J18-1 J18-2 is connected to a 65 c switch.
            J18-3 J18-4 goes to a 90 c switch.
              the dude is correct ! i traced it through the amp and found those 2 parts hidden under a big heat sink
                It's possible that the part is a dual coil inductor made by Murata.
                https://www.google.com/url?sa=t&rct=...VQGXXOREepIZ0S
                  Most probably.
                  If labelled jtīs a commercial product; if unlabelled itīs probably aplain generic ferrite bead.
                  Although the commercial products may be as simple as same ferrite bead or slightly larger one with a single or dual wire loop through it.
                  The difference being (maybe, wild guess follows) that a human must pass a wire through a ferrite bead while one with a wire preinserted (and with ends pretinned) can be inserted in a PCB at the rate of 1200 an hour or something like that.
                  Mighty Terminator will rule the Earth.
                    But he won't build "my" amps (though he may hunt me down and scrub me into red goo on the asphalt )
                      Most probably.
                      That sounds real plausible but what's up with those reference designators, I don't ever think I have seen a schema like that before... kind of cryptic. 9L122uH the 9L is the ninth inductor maybe? the schematic uses things like 8C for a capacitor and like that. Is 122 micro henries reasonable for that application? I think that's the value, it's a composite reference designator/value marking maybe... yeah strange... no! I see it now! the (9) is the circuit group the next two are the reference designator (L1) and the last 4 characters are the value (22uH)... yeah, strange.
                      ... That's $1.00 for the chalk mark and $49,999.00 for knowing where to put it!
